no check engine light help.
Old Feb 28, 2005 | 11:45 AM
mean57's Avatar
Car: 87 gta
i trying to start motor after changing some things had all power to gauges lights etc. tried starting a couple times and cranked and backfired. tried about three time to get car to start. then thought {NOOOO!} I DID NOT HAVE A GROUND FROM THE MOTOR TO CHASSIS. now the check engine light does not come on when the key is cycled? bulb is good
any suggestions greatly appreciated
Old Feb 28, 2005 | 02:49 PM
mean57's Avatar
Car: 87 gta
ttt
Old Feb 28, 2005 | 03:02 PM
kevinc's Avatar
Car: 1982 Z28
(double post)
Old Feb 28, 2005 | 03:03 PM
kevinc's Avatar
Car: 1982 Z28
Easy two-step process:
1.) Have someone kick you in the nuts.
2.) Check all fuses and fusible links.
Old Feb 28, 2005 | 03:05 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
When my check engine light didnt come on with the key forward it was simply a 20 amp fuse located right in front of the battery, it goes to the fuel pump, if your oil pressure sending unit goes bad it will blow this fuse.
Old Feb 28, 2005 | 03:19 PM
mean57's Avatar
Car: 87 gta
yes, the kick in the nuts did it!!!
there is a short in the wire to the fuse to the pump.
repaired: car fired right up thanks dan8289gta my brain was fried after 12 hours of aftermarkrt part installs.
Old Feb 28, 2005 | 03:42 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
No problem, i know the feeling
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
