Ignition coil and bracket for TPI??
Old Mar 8, 2005 | 11:21 AM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey guys,
Anybody here know of any seperate ignition coils with the dual connector being sold from any aftermarket brands with a coil bracket that can be mounted to the firewall? Ive tried Crane, and they only make those brackets for ford and not chevy.
Old Mar 8, 2005 | 12:47 PM
subliminal's Avatar
Yes the MSD Blaster Coil. All you gotta do is unbolt the stock one then drill the rivets out of the stock bracket, then use the screws and nuts provided to put the stock bracket onto the new coil and bolt it back on. Pretty simple to do. You can get a MSD blaster coil for about 40 bucks at Pep boys or any speed shop.
Old Mar 8, 2005 | 03:19 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I got the MSD blaster coil and couldn't figure out the cheesey bracket (looked weak too) so i drilled out the rivits on the stock coil bracket and reused it.....worked perfect for me.
Old Mar 8, 2005 | 03:38 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Yep, I had my mechanic install a MSD blaster coil when I had my MSD distributor installed. He indicated there was some modification. You may want to think about some new spark plugs soon after with this new coil.
Old Mar 8, 2005 | 03:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
This guys not asking to reuse the stock bracket, he's asking if there are ones that will mount to the firewall.
Old Mar 8, 2005 | 07:22 PM
vortec77's Avatar
Car: 86 T/A
Right!! I dont have the stock bracket, im trying to buy a coil and bracket together to mount on the fire wall, i dont have the bracket that goes from the coil itself to the "z" bracket that mounts to the intake manifold.
Old Mar 8, 2005 | 07:33 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
I made mine fit in to the one made by accel(i think). It came from a ford coil that my friend gave me. I just tossed the coil itself.
Old Mar 8, 2005 | 07:53 PM
vortec77's Avatar
Car: 86 T/A
Hey Wacky, car looks nice!! thinking about getting that hood!!
Old Mar 8, 2005 | 08:03 PM
Car: 92'Camaro RS
Engine: a loud one
I got it now, sorry about that vortec.......whn i did my swap, that was the piece that was missing, took me a while to figure out that it was missing. I got one at the dealership. Not sure where you'de get one if you wanna mount it on the firewall.
Old Mar 8, 2005 | 09:44 PM
vortec77's Avatar
Car: 86 T/A
LOL, whats really sad is i work at a dealership and my parts guy doesnt know what im talking about!
Old Mar 9, 2005 | 05:08 PM
vortec77's Avatar
Car: 86 T/A
Anybody have any pics of their coil so i can at least see what it is supposed to look like??
Old Mar 9, 2005 | 07:08 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
This is how my stock coil is mounted. The coil is stock but not the position.
Old Mar 9, 2005 | 07:11 PM
vortec77's Avatar
Car: 86 T/A
Thanks iansane, is that the z bracket under the coil?
Old Mar 9, 2005 | 07:43 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
It's half the Z bracket I guess...
Look at this thread for a better diagram of the stocker.
Old Mar 9, 2005 | 09:16 PM
vortec77's Avatar
Car: 86 T/A
Thanks again Iansane, that helped alot!!!
evilstuie
Jan 9, 2020 08:29 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
92projectcamaro
Aug 6, 2015 01:20 PM
