Runner Gaskets
Old Mar 10, 2005 | 04:11 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Runner Gaskets
I am porting and polishing my plenum and runners this winter and was wondering if i should replace the runer gaskets when i reinstall everything. Thanks in advance.
Old Mar 10, 2005 | 04:49 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Yep.
Old Mar 12, 2005 | 12:41 PM
1988 Massz's Avatar
Car: Acura now/Z in the summer
Engine: 5.7 tpi
Yes replace them because I ran into the same situation with removing the plenum and runners myself last january. I removed the original oem gaskets and replaced them with the felpro gaskets after cleaning up the intake surfaces. Well I had a major compression leak and the car was whistling dixie and popping popcorn from leaks 2 of them. I pulled everything apart again and come to find out 2 of the felpro gaskets were junk. What I did was I ordered the slp runners and there gaskets. The gaskets they sell are alot nicer than the felpro. I found also they had a nicer fit to the gasket surfaces. I was also more tedious with smoothing the intake gasket surfaces the second time also. The second time also I place the runners and plenum with all the torque bolts loose and worked them in symmetricaly one at a time also so the runners mated perfecly with the intake and plenum. This itself did the trick no more leak and ran sweet. You can order the slp gaskets seperate from the runners if you wish hope this helps.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
Royal_Z
Sep 30, 2015 08:45 PM
