prom questions
Old Mar 12, 2005 | 04:14 PM
Dioak88GTA's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
Transmission: 700R-4
prom questions
88 tpi gta 5.0 auto and i purchased a 87 tpi camaro 5.7 auto prom and computer...will this result in any problems? i know the computers are the same but the proms are different b/c of the 19lb injectors vs the 21lb...but other than that...think that will effect anything?
Old Mar 14, 2005 | 12:28 AM
Vader's Avatar
There are some other differences in the programming. You should be able to swap your '88 MEMCAL into the '87 ECM and install it in your '88 with no problems.
Old Mar 14, 2005 | 09:39 PM
Dioak88GTA's Avatar
Engine: 5.0 TPI
my computer was fried and i dunno if that prom is any good ne more
Old Mar 14, 2005 | 10:01 PM
Vader's Avatar
The calibration of the PROM for the 350 will be way off for your 305. You'll need to either replace the MEMCAL with one for a 305 or try your original.
Old Mar 15, 2005 | 01:02 PM
Dioak88GTA's Avatar
Engine: 5.0 TPI
i'll see if mine still works...hopefully it does, if not then i guess i'm screwed for now
thanks
Steven 86IROC-Z
May 24, 2026 04:52 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
