Need input on L-98 Rebuild
Old Mar 18, 2005 | 08:05 PM
moose350's Avatar
Recently aquired a complete L-98 TPI engine from a '90 Vette. I have purchased a zz4 cam, Speed Pro H631-CP pistons, .030 over. Need advise on the rocker arm selection, pushrods, rods, computer chip, and any other info that would be helpful prior to start of rebuild. Car will be street driven only, auto, with 3.07 posi. Would like to make 300+ hp. Budget is $1,500. Thanks.
Old Mar 19, 2005 | 07:04 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I would say just keep your rods, but have them looked over, shouldn't cost you over $10-15 per rod. Just get some new bolts like ARP's for them. Unless you are planning on running forced induction then look at some forged ones, but even then your stock ones should handle quite a bit. As for the computer chip burning one yourself is the absolute best because you will be able to log your own data and make all kinds of changes until it is just right. but most people do not have that luxury. I would say contact Ed Wright for a good one otherwise I have heard some good and bad things about PCMsforless.
Old Mar 21, 2005 | 05:52 AM
3rdgenstm's Avatar
Car: ‘92 Z28
Slap a carb on it! Ha ha!
Does anyone think roller rockers and a bigger throttle body would help him get to the 300-350 mark?
Moose-- have you had any exhaust work done already? If not a catback, headers, and a hi flow cat will do wonders for any engine.
Old Mar 21, 2005 | 06:51 PM
moose350's Avatar
New exhaust from catback. Not sure about roller rockers, how much HP gain? What is good brand, Scorpion or Crane?
Old Mar 23, 2005 | 05:47 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I'm running the Comp Pro Mag roller rockers and they are very nice rockers.
It's difficult to quantify how much HP gain you'll see, but roller rockers will actuate the valves a lot more precisly and repeatably since they don't flex like stockers do. Plain rockers will make your oil temp hotter too.
Can't go wrong with Comp pushrods. I'm running ~400 lbs of spring press and haven't had any issues with the rockers or pushrods.
Definately burn your own chips. It's easy to do and the equip costs less than one aftermarket chip.
Old Mar 23, 2005 | 08:18 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Roller rockers are good for at least 20 horse on a 350.
If your going to spend the money get them from a reputable brand name thats been around like Crane or Comp (pay now or pay later ) if you do get Roller Rockers be sure to get hardened push rods as well.
cheesehomer
Dec 31, 2015 08:48 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Linson
Oct 1, 2015 09:50 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
