Tachometer Connection for Tuneup
Old Mar 22, 2005 | 02:25 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Can someone post some details on connecting a diagnostic tachometer to the TPI distributor. I want to do the IAC and TPS check/adjustment for my idle speed which is currently too high. However, I can't figure out how to connect a tachometer to the distributor or coil. Can someone put up a diagram or photos of how this can be connected. I have an older tach for distributors with the coil and points but nothing with the HEI and separate coil. I even have a multimeter that can check this if I know where to put the red and black line pins into the connectors.
Thanks,
Scott
Old Mar 22, 2005 | 04:10 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Take the wire on the tach for "negative side of the coil" and splice this into the wire on terminal 'R' on your distributor -- on the 4 wire connector, it should be the 3rd one, counting from the left. If you pull the cap off, you should see the module labeled 'GBRE'.
Anyway, terminal R is a tach-reference signal and should give you what you are looking for.
-Dave
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
