ignition trouble, then muffler explodes!
Old Mar 22, 2005 | 08:40 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
you guys are going to love this. i was driving to a dr appt yesterday, when all of the sudden the check engine light comes on, and about 2 seconds later the car dies. i pull it into some ladies driveway, try to start it and it just cranks. could smell gas, so im pretty sure it isnt a fuel problem. i tried to check the codes and all it gives me is 12. i tried starting it quite a bit, and for the most part it just cranks but 2 or 3 times it sounded like it wanted to start, sounded like it normally does starting for maybe a second, then died. well the 3rd time it did that, it backfired, and blew my flowmaster 80 series muffler apart! one just gaping rip in it and a smaller hole maybe an inch around. now i've never had any sort of trouble with the engine backfiring, or ignition trouble before. i checked most of the wires, and none of them showed any spark. i believe my motor runs about 9.8:1 compression based on what the previous owner told me, anyone heard of a motor just blowing the muffler while being cranked? how do i go about diagnosing the ignition and pinpointing the problem? thanks a lot,
Shaun
Old Mar 23, 2005 | 12:45 PM
AdioSS's Avatar
Car: 96 Impala SS
I'm gonna guess that you dont' have a catalytic converter... or if you do, it is stronger than the muffler was.
While you were cranking the injectors were pumping fuel into the motor. There was no spark, so it didn't burn and just passed through then collected in your exhaust. When it did finally spark, the fuel in your exhaust caught fire. The weakest point in the system gave.
Old Mar 23, 2005 | 12:56 PM
firebirdjones's Avatar
had that happen
My father had that happen, it turned out that the timing chain had worn and jumped a few teeth, He blew both mufflers completely off of a new system. Pretty funny stuff.
I am not saying that is your problem but this is one thing that will cause this problem. Just one mans experience, Larry.
Old Mar 23, 2005 | 08:34 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
It could be a number of things. My car every now and then stumbles when it runs hot and somtimes tries to die but when I do kill the motor and the motor and starter are already heat soaked it struggles to start at times.
Well about your exploding problem. You pretty much summed it up. After you cranked for a while your motor is spinning throwing unspent fuel through the exhaust system then finally when it gets close to turning over and getting spark on a few cylinders but not enough to start the fuel through out your exhaust system ignites and guess where in your exhaust system the most air is available and muffled at the same point and time.
Same thing happens when you have NOS and accidently for get to turn the switch off while flloring the motor and cranking except somtimes the explosion is the intake...Dont ask how I know that one...
Old Mar 26, 2005 | 03:24 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
your car is just telling you that it dosent want to be chocked by th e muffler anymore... its your cars nice way of saying get rid of it.
Old Mar 26, 2005 | 09:14 AM
1meanGTA's Avatar
lol!!!
Old Mar 26, 2005 | 07:22 PM
iroc_3030's Avatar
Car: 1988 camaro irocz
Engine: 350 tpi
what is causing the motor to do this though, i am having problems right now that my motor wouls seem like it was missing when it got warmed up, then i put new wires and plugs on it and now it wont start and the muffler backfires, does anyone know the cause of this, maybe out of time or something like that. i need help with this because my car is all i have right now and i have to go back to school next week. any help would be appreciated
Old Mar 27, 2005 | 01:29 AM
robsgta's Avatar
Hey Iroc 3030 you need to start your own thread If you have a problem.
Sounds like you crossed your spark plug wires....
Old Mar 27, 2005 | 08:59 AM
iroc_3030's Avatar
Engine: 350 tpi
i thought maybe these threads would help me so my bad and i have had them checked by a mechanic and they are not crossed so i dont really know whats wrong i guess
PurelyPMD
May 5, 2016 04:57 PM
RedLeader289
Sep 23, 2015 06:50 AM
cstrobel65
Sep 16, 2015 11:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Jlanz55
Sep 6, 2015 02:35 PM
