heads and cam
Old Mar 25, 2005 | 12:50 AM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
heads and cam
i'm rebuilding my 350 tpi. i will be going with the super ram. i was going to stick with stock ported heads but ws wondering if these would be worth the money heads .also i will be putting light weight corvette pistons in it, a 2800 stall, it already has headers and exust and will get a custom prom, underdrive pulleys afpr. would this be a good cam to go with this combo would i be able to use the stock roller lifters and the stock rockers? also what would i have to do t the heads to be able to use this cam? If not this cam, what cam should i go with. i diont want to have to change any vacum.
Thanks for any help!cam
Old Mar 25, 2005 | 04:34 PM
purplebird's Avatar
Engine: 5.7 tpi
ttt
Old Mar 25, 2005 | 09:07 PM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
the stock superram intake will not fit these heads. a vortec specific intake is needed and scoggin dicky (sdpc.com) is the only one that makes it. it alone is like 400 bucks. the vortec heads have to be machined to accept higher lift cams( anything over 4.75 lift). im no head man so youd have to do a search on here to find out exactly what has to be done to these heads, but i know ive heard from several people this is true. do a search on here b/c i know its been covered.
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
