Anyone ever seen this one before?
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
From what i understand it's a supercharger kit that flows 500 cfm of compresssed air into you're throttle body. I guess it runs off your car battery.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
one day im gonna try that **** on a lawnmower and see if i can yeild some gains from that. If not them im gonna post it on the power adder and ask for it to be a sticky
Toro v. I or II + 5hp Briggs & Stratton=Supercharged
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea i seen kits for that and a coffee you can use for an exhaust tip for hondas...pretty slick
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
found this on a corvette forum looking up heads, that might help to cool down the engine assuming you put in a bigger alternator, but not in the intake system
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I actually messaged someone that bought a similar item on ebay. I asked if he saw and performance difference his almost exact words were "Yeah, I'd guess about 40 hp but my mom won't let me take the camry to the track"!!!!!!!!!
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
Now that is junk. But I used to do landscaping and we had a stihl backpack blower that was rated at 1500 cfm. If someone wanted to try this they should use this to see if gained any power.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
its not worth it, it might be some what decent if it was a gasoline leaf blower
But completely impractical. Yeah the only engines that might respond to something like this would be a very small 4 banger or a small v-twin. There have been pics on here of Corvettes and Camaros and every other backwoods idea to kill power. If you want to supercharge by a turbo or vortec.
Also keep in mind the amount of power needed to actually move air with a electric engine.
But completely impractical. Yeah the only engines that might respond to something like this would be a very small 4 banger or a small v-twin. There have been pics on here of Corvettes and Camaros and every other backwoods idea to kill power. If you want to supercharge by a turbo or vortec.Also keep in mind the amount of power needed to actually move air with a electric engine.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
that thing CAN NOT compress air.. which is what a supercharger does..
500CFM?? if thats in the way of the intake.. the 48mm throttle body is 650cfm(correct me if im wrong)
so wouldnt that mean that it is robbing 150cfm from the engine?
to add 500cfm to the engine.. it would already need 650 to push what the engine needs in stock formation.. so to add 500cfm additionally.. would need to be 1150cfm...
am i wrong?
that thing is
am i wrong?
that thing is
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I don't know which has a higher degree of stupidity:
1) Someone actually trying that and thinking it will work (i.e. 40 hp gain on a Camry).
2) Having a yellow $20 AdvanceAuto Parts air filter resting on your Corvette's water pump pulley.
3) Watching someone open the hood, and start the leafblower before they turn on that monstrous L03.
