Which is more effective?
Old Mar 27, 2005 | 12:08 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
switching to a Heated O2 sensor.. but i have a question on which is a more effective place for it..
should i mount it in my Hooker 2055's on the driver side where it normally goes? or would it make a difference if i put one it in the Y pipe before the CAT?
Old Mar 27, 2005 | 12:13 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Try to mount it as close to the collector as possible (headers) or just after the factory cast iron manifold. You want four cylinder's worth of exhaust blowing past that sensor.
Take your time if this is a new install- you get to decide where to put it so you may as well put it in where it is easy to get to!
Old Mar 27, 2005 | 12:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Do forget to orient it away from the down side of the pipe to keep moisture out of it.
Old Mar 27, 2005 | 07:42 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
If you don't plan on burning a chip .....keep it as close to the stock location as possible or it will mess up the A/F ratio
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
