map sensor readings
Old Mar 28, 2005 | 08:40 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
map sensor readings
is there anyway to trick the ecm to think that the map sensor is reading lower voltage............
my problem is the map sensor is redaing like the throttle is at wot...........this is causing my car to run very rich.........my mods are in my sig
Old Mar 28, 2005 | 08:53 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
How about finding out WHY your map sensor is lying? Fix it once, fix it right, and don't worry about it agian. (well, until the next time anyway, but, hopefully, that will be a while...)
Old Mar 28, 2005 | 09:05 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I've seen big camshafts mess with the vacuum at idle, making the fuel pressure regulator add more pressure causing it to run rich. Is this what you mean by your question?
Old Mar 28, 2005 | 09:39 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
my map is reading 3.0 to 3.5 v at idle...........about 50 to 60 kpa at idle......my fuel pressure is set at minimum but the ecm is thinking i'm at wot and making the injectors stay open longer
Old Mar 29, 2005 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A '92 TPI is a speed density system. Then some parts: Comp Pro Mag 1.6 rockers.Lt4 hot cam.Corvette Lt1 injectors.
It will be running quite rich at low speeds. And probably lean at high engine speeds/loads. Need to tune it, that's all. Basically the VE tables are now way off. And the injector constant needs to be changed.
RBob.
Old Mar 29, 2005 | 05:50 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
RBob.
i just payed out my **** for a custom chip that isn't doing it's job..........and i haven't gotten used to burning my own......
Old Mar 30, 2005 | 10:49 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Where did you get your custom chip, as I am in the market as well? I need one burnt myself....
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
squiggy2
Aug 9, 2015 09:30 PM
