5.7 TPI PROM questions
Old Apr 2, 2005 | 05:24 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I bought a 1990 IROCZ 5.7 TPI w/G-92 over a year ago, and have been wating to work it into my plans since. I finally got to put it back together after it came back from the body shop. Some drivability problems have appeared that confound me:
1) Idle quality in open loop is acceptable, but deteriorates in closed loop.
2) My Snap-On scam tool says "mismatched"
3) Torque Converter lockup appears to be erratic
4) The PROM in the 7730 ECM is a Hypertec 120322
5) I have a spare 7730 ECM from a V-6 car, and I notice the PROM is much longer and fills the entire PROM area, and has a blue "carrier".
6) It used 5 gallons of gas in 63 miles
My question is; Should I get an original type PROM?
Fuel pressure regulator, and MAP sensor have been replaced.
Old Apr 2, 2005 | 08:43 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
es, if for nothing more than a base line.
Old Apr 2, 2005 | 10:13 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Have you done a basic tune up on it? A bad O2 sensor could be causing the crummy idle in closed loop. I'd try to find an original Prom for it but the Hypertech one should run it "ok".
Look carfully at your prom that is currently in there. See if perhaps the stock blue carrier is attached to the side of the board that the Prom is attached too. The other stuff like Limp home mode are not on the prom and I can't imagine that Hypertech would eliminate them.
Old Apr 3, 2005 | 06:30 AM
ANDYZ28's Avatar
Car: 1982 Z-28
The Hypertec PROM only seems to use about one half of the PROM location on the ECM. The stock blue carrier is missing.
I am unable to read any engine data because the Snap-On scan tool cannot seem to read the info "mismatch" is all is says when I attempt to connect it. I am wondering if the Hypertec PROM is causing this?
Old Apr 3, 2005 | 07:52 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You are looking in the right direction.
Old Apr 3, 2005 | 11:16 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
It sounds like you have something similar to the picture below. If you do, then from I can tell, you don't have a memcal hooked up on it. You need an AUJP memcal (90-92 350 auto), and you need to either use that memcal instead of the hypertech, or mount the memcal on the 90 degree pins that the hypertech has.
The car will not run right until you do one of those two options. Do not use a 305 memcal, or a V6 memcal, they won't work right either.
Old Apr 3, 2005 | 05:25 PM
ANDYZ28's Avatar
Car: 1982 Z-28
For some reason I was unable to view the attachment. My computer wants to know what program I want to use to open it?
I have the feeling I need to locate or just buy the correct GM part.
Old Apr 3, 2005 | 06:08 PM
DJP87Z28's Avatar
Just buy a stock GM 350 chip from the Dealer for about $50. That will give a base line to work from.
Old Apr 4, 2005 | 03:04 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Let me try to post the pic differently....
Old Apr 4, 2005 | 03:05 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Not sure why its coming up as a link instead of displaying the picture. Try opening it with Microsoft Paint, it should work fine.
Old Apr 6, 2005 | 04:45 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
What kind of file are you trying to attach? Nevermind, it's a jpg. The download works fine for me. I can see the pic of the Hypertech mem-cal adapter.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
