best heads for tpi 350
Car: 1988 camaro irocz
Engine: 350 tpi
what are the best aftermarket heads on a tpi 350, and what is the best cam for this engine as well. its an 88 so i do not know what heads i have at this time but would like to get better heads and cam and eventually get better intake. any ideas?
I was really happy with plain GM L98 aluminum Vette heads and their HOT cam back when I ran TPI. Made ~290hp/360tq at the rear wheels with no porting or polishing on the heads, idled a tad lopy and passed NJ treadmill emission testing easily.
Scan of the dyno sheet with a 52mm TB, polished stock runners, Accel TPI base is here:
http://www.mycar.net/mafb/registry/d...id=963&ref=det
Originally posted by iroc_3030
i have the l98 heads im pretty sure already, so did you port and polish your runners too?
I polished the insides of the runners just to clean up the junction of the tubes and the plates. There's not much material there to do porting work on.
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
The thing is that stock L98 Heads dont flow as nice as something like Dart 180s or some of the other after market heads.
Also you have to understand that if you change out from Cast Iron heads to Alm, the Compression should be higher. cast iron heads are best at 9-9.5:1 where Alm. Heads are best at 10-10.5:1 or even higher depending on your cam
My L98 was just rebuild & bored out to a 355 with a lingenfilter cam & will get Dart 180 Alm straight plug heads as soon as i get the money.
is the ligenfelter cam better than the hot cam i have heard about?
Re: 14.6
krazzycowgirl,
what did you have done to your 350 when you ran 14.6
krazzycowgirl,
It was also a very cool day out side bearly even 60 degrees & we were at sea level.
do you think the hypertech chip gave you much time off your et
Oh I forgot that I also had an airfoil in it too.
But last year I had sucky times because I had to Launch at idle due to the fact of if I didnt the car would go side ways. This year I am not racing the car since its ripped a part in my garage with the new engine sitting beside it. not even ready to go in.
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
