What will happen if there is a vacuum leak?
Old Apr 6, 2005 | 05:32 PM
white89_350's Avatar
I found a vacuum hose that had been burnt through pretty good. What signs will occure due to a bad vacuum line with a gaping hole? My car sounds like there is a cylinder missing or something and a little less power the rpms down low.
Old Apr 8, 2005 | 10:58 AM
ttt
Old Apr 9, 2005 | 08:09 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Depends on the size of the leak......if it's big enough, you can actually burn up a motor....valves, seats and pistons.
You said yours was a hose...was it a little plastic hose or a big rubber one?
Was it running that way after you fixed the leak?
Old Apr 9, 2005 | 03:56 PM
Have not fixed the leak yet. Where do you get those little rubber vaccum hoses?
Bubbajones_ya
Jul 6, 2024 08:32 PM
bbsr72
Sep 27, 2015 05:55 AM
IROCtometal
Sep 9, 2015 10:01 AM
hdis2002
Sep 8, 2015 02:52 PM
rjcme
Sep 5, 2015 01:23 PM
