1985 burn-off relay
Old Apr 6, 2005 | 10:59 PM
tpicamino's Avatar
1985 burn-off relay
where can i get a maf burn off relay ? what is diffrent about the 86 relay to the 85 relay ? will a car quest store be able to get one ? does any one have a 85 relay they will sell ?
Old Apr 7, 2005 | 12:13 AM
Guest
Guest
Posts: n/a
The 85 uses a MAF 'module'
Its insanely expensive, and hard to find.
You might want to consider swapping your ECM to a newer MAF setup, or a speed density setup. Thats if its the module is the problem with your car.
Old Apr 7, 2005 | 12:18 AM
tpicamino's Avatar
how much is that ? its back firing , wont idle ect
Old Apr 7, 2005 | 10:14 AM
Guest
Guest
Posts: n/a
Last price I heard was in the range of $800. You might be able to find a 'good' used piece for less, but I dont think I have ever heard of someone getting one for less than a couple hundred.
Old Apr 7, 2005 | 10:21 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i have a complete 85' sys from my iroc if u wanna buy em'
Old Apr 7, 2005 | 10:23 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i have the ecm, burnoff sys, cruise control module, etc
Old Apr 7, 2005 | 11:29 PM
tpicamino's Avatar
this is for a friends car , how much just for the part to fix it ? some pics would be nice
Old Apr 7, 2005 | 11:41 PM
tpicamino's Avatar
Re: 1985 burn-off relay
what all has to be done inorder to do this ?
also where on the passanger side is this relay located ?
thansk
Old Apr 8, 2005 | 01:07 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Relax, be happy, it should be available at your local parts store. If not here's a link. The site even tells you where the relay is located.
fbodymotorsports.com
Old Apr 8, 2005 | 03:45 AM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
Too bad that doesn't apply to the MAF module for the 85 which is located behind the dash plastic on the passanger side.
Old Apr 8, 2005 | 04:02 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
So the 85' doesn't have a MAF power, or burn-off relay?
Old Apr 8, 2005 | 09:07 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The '85 ecm has a module attatched to it, or below it that is callled the MAS module, it is what controlled the burn-off function for that year. It sucks, it's expensive and it's a PITA.
Old Apr 8, 2005 | 09:10 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i have all that stuff, who wants to buy it???
Old Apr 8, 2005 | 11:39 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Should one ask why you have all that stuff?
Old Apr 8, 2005 | 12:05 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i have 85 iroc-z, its completely gutted... re-doing real big! new interior, rims/tires, seats, paint, engine, tranny, lights, etc... everything is in my garage in boxes... so since im getting all new stuff , i might as well sale the old stuff.....
Old Apr 8, 2005 | 12:07 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
by the way, the car did run at one point.... before i disconnected everything... batt, ecm, dash, harness, etc..... (still cannt get those 3 wires leading into the rear hatch but thats another story (thread..) ha ha
Falcon50
Aug 22, 2020 03:26 PM
Lbibb
May 5, 2016 12:00 AM
thunder57
Nov 7, 2015 02:28 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
