interesting find might help dyno #S?
Old Apr 9, 2005 | 09:39 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
Well guys if you followed the post about the dyno results after the dual exhaust was installed along with a chip by ski_down_it I was at 254 hp & 315 tq if I remember right, I dont have the dyno sheet here with me.
Well I decided to check the TPS sensor readings yesterday after work and found it still set at .62 which is were it was set at before the cam install.
I also checked the throttle opening and found I was only getting at most 3/4 throttle, the TV cable for the trans is holding it for some reason, I moved the detent aprox 3 clicks forward now the throttle will open all the way.
Any idea how much this will affect the power and torque?
Old Apr 11, 2005 | 12:38 AM
DON 88T/A's Avatar
Assuming that your shifting at a proper RPM, the increase in airflow should help a bit......how much would be guessing.
1992rs/ss
Jan 31, 2025 05:10 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reborn756
Sep 4, 2015 03:42 AM
