Crazy Idea/Question!?
Old Apr 12, 2005 | 11:55 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I was thinking the other day all the possible reasons why I might be getting some WOT ping. My oil pressure gauge has been kinda freaky ever since I got the car, but in the last few months, it's started dropping down to zero in traffic and what not. Now I know this is not really happening. Anyway, I looked at the connector to the sending unit and noticed three wires going to it. Someone told me that one of them has something to do with the fuel pump, and in the event the motor were ever to lose oil pressure it would shut off the pump. Do any of you think that a faulty oil pressure sending unit could trick the fuel pump into shutting off intermitently, or not provide enough fp at wot? I replaced my fuel pump, filter, and gas tank months ago, and it still did it. But since changing the oil pressure sending unit the other day, the ping appears to have stopped. At least I can no longer hear it. If anyone can chime in on this, seems like a long shot, but I thought it was weird.
Will
Old Apr 14, 2005 | 12:15 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Don't assume its gone because you can't hear. Don't say that until you confirm it with a laptop or scantool (and even then its not 100% sure). The oil pressure sender acts as a fuel pump cutoff in the event that oil pressure drops under 4 or 5 psi.
Old Apr 14, 2005 | 12:21 AM
norcalz28's Avatar
I have a laptop, but where can I get the serial cable and software to monitor such things?
Will
Old Apr 14, 2005 | 08:13 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Click the diy prom board in my sig and hit the stickies at the top.
later
Jeremy
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
