modified mass air?
Old Apr 13, 2005 | 11:52 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
modified mass air?
has anyone ever moded their mass air? i was reading that you can take out the screens and shave down the little prongs or whatever that's called and make it flow better.
is there a step by step? i tried searching
thanks
Old Apr 13, 2005 | 01:56 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
http://www.geocities.com/MotorCity/T...mafscreen.html
Old Apr 13, 2005 | 02:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I ported the intake & plenum, I also took apart the TB installed a air foil, and then bored it out 52mm, and removed the coolant system.
I removed the screens, but I won't do anything else to the MAF until I'm sure I can recalibrated it, otherwise I'll go with speed density.
Old Apr 13, 2005 | 06:01 PM
mcwille's Avatar
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
DO NOT MODIFY YOUR MAF!!!!! other than screens...... find the post "i f***ed up" yeah thats my $0.02
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
