i'm pissed now...injector....
Old Apr 13, 2005 | 10:18 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I just put together my superam, which took forever, and when I went to lock the injectors in to the fuel rail with the injector clips/locks,...one broke. I think the only way to change it is pull the whole superam apart and take off the fule rail again. I really don't want to do that...Is there another way? Or can i get a c-clip that size or maybe even just leave it off completely. Is is that important? the injector seems to be seated tightly,. it's just a little easier to move from side to side.....but the wire harness holds it in pretty good. The injector won't be able to move up and down without the clip will it???? it seems seated well. Do I really need it? thanks
Old Apr 13, 2005 | 10:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Heck I dont run any clips, and my injectors are shorter then yours. You'll be fine.
Old Apr 13, 2005 | 10:54 PM
Car: 1987 GTA
that's good to hear, thanks. ...however,....not to be a wiseass,...but why did GM origianlly design them and put them on? what are they for? thanks man
Old Apr 13, 2005 | 10:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I guess to hold them in lol. My LS1 injectors that I am using in the stock rail can accually be moved up and down since they are shorter but so far so good and no leaks
Old Apr 13, 2005 | 10:57 PM
Car: 1987 GTA
ok, that makes me feel better, why aren't u using clips..?
Old Apr 13, 2005 | 11:48 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think their original purpose was to hold the injectors to the fuel rails for assembly purposes...
Old Apr 14, 2005 | 07:27 AM
Car: 1987 GTA
seriously? that's good news, thanks
85 Jimmy
Sep 30, 2015 07:56 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
djmarch
Aug 19, 2015 12:07 PM
legendaryhero7
Aug 12, 2015 06:19 PM
91FastBird60kmiles
Nov 19, 2000 10:03 PM
