Can any of the accessories be spun backwards?
Old Apr 22, 2005 | 01:55 AM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I removed the AIR pump on my 91 corvette, and I was considering re-routing the belt to avoid having to buy or build an eliminator bracket. Can any of the accessories be spun backwards? Water pump, AC pump, alternator, power steering pump, etc...
I found this the other day and haven't had a chance to try it yet. The accessories are mounted a little bit differently in a corvette so I'm not sure if it will work or not.
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Thoughts?
Old Apr 22, 2005 | 11:26 AM
Guest
Guest
Posts: n/a
Water pump, no... not unless you change it to std. rotation. Alternator shouldnt matter except the cooling fan, but I am not sure about the PS. I would think no.
Got a belt diagram?
Old Apr 25, 2005 | 01:44 PM
neat's Avatar
Car: 1991 Corvette
I have a belt diagram, but I don't have a way to post it.
Anyway, after some more research, the alternator is the only thing that can be spun backwards. There is just no way to make it work on the corvette L98.
I guess I'll have to buy or build an eliminator bracket.
Old Apr 30, 2005 | 11:23 AM
Vader's Avatar
Convert the image to *.jpg format, reduce the size until the file is 100Kb or less, then attach it to your thread.
Old May 1, 2005 | 01:37 AM
neat's Avatar
Car: 1991 Corvette
Lol, no the belt diagram is on the fan shroud under the hood of my car. i don't have a way to take a digital pic of it.
I built a bracket anyway, so it's a moot point now.
BDR
Nov 7, 2015 03:05 PM
mrbird
Oct 20, 2015 03:43 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
355tpipickup
Sep 28, 2015 05:50 PM
Mdenz3
Sep 17, 2015 08:36 AM
