What is this????
Old Apr 27, 2005 | 08:08 PM
subliminal's Avatar
What is this????
There is a wire that is disconnected on my car, I dont have a pic but I will describe it the best I can. It is a black wire with a single piece of metal kinda in the shape of a needle at the end. there is a piece of green rubber where the wire connects to the piece of metal. It is on the passengers side of the below the exhaust manifold. I am having spark knock and I believe this wire being disconnected may be the cause. If anyone could help me with this Id greatly appreciate it. Thanks alot.
Old Apr 27, 2005 | 09:59 PM
Vettefan87's Avatar
Car: 1987 Corvette
I wonder if it is the knock sensor, which would explain the issue of your car having some spark knock. Do you see where the wire goes? You might try hooking it back up and see what happens.
Justin
Old Apr 27, 2005 | 10:02 PM
subliminal's Avatar
nope dont see anywhere it could possibly fit. its not to the knock sensor
Old Apr 27, 2005 | 10:09 PM
mean57's Avatar
Car: 87 gta
there are 2 sensors on the block on that side of the motor.
1 knock ssensor, 2 fan switch. one is most likely unplugged check and see. not to be a antogonist but you are positive the knock sensor is plugged in?
Old Apr 27, 2005 | 10:12 PM
subliminal's Avatar
Well there is something on the passenger side of the block that is plugged in, i assumed it was the knock sensor
Old Apr 27, 2005 | 10:54 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Knock sensor is just above the oil pan, screwed into the drain hole, in about the middle of the block.
Fan Switch is in the head between cylinders 6 and 8.
Check both. They used a crappy "squeeze" connector that inevitably gets brittle, and breaks. Not sure what GM was thinkin' there.
Old Apr 27, 2005 | 11:20 PM
subliminal's Avatar
yup i saw that thing between the plugs however this wire will not fit into that, also my fans are set to run whenever the ignition is on so i dont think a fan switch would be needed.
Old Apr 27, 2005 | 11:21 PM
subliminal's Avatar
the code 42 isnt constant it is intermitten car will run like crap then when i shut it off it will run a little better and the light goes away
