Vacuum line issue
Old May 3, 2005 | 03:37 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
Vacuum line issue
There is a vacuum line that goes to the thing underneath the ignition coil. It goes out, very long, part of it connects to the throttle body...can someone tell me where the end of it connects to? mine seems to be broken, but I still dont know where it goes.
Old May 3, 2005 | 07:57 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: Vacuum line issue
Sound like your talking about the EGR solenoid. There are two lines that go to the solenoid, one goes to the EGR valve from the solenoid and the other runs to the small vacuum port on the lower left hand side (drivers side) of the Throttle body also running from the solenoid. Hope that helps.
Old May 3, 2005 | 08:02 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
well. thats the line im talking about...but the issue is that after the port for the TB...it goes out more. i need to know where it goes after the TB one.
Old May 3, 2005 | 08:43 PM
Vader's Avatar
The timed vacuum port on the underside of the TB is routed to both the EGR solenoid and the EVAP canister purge valve/solenoid.
Infested
May 22, 2018 11:56 PM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
