TPI on a 400
Old May 11, 2005 | 09:12 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
TPI on a 400
I have read TPI on a 400 offers a ton of torque but little horsepower. If I bought different runners, something like this:
Hi Flo Intake runners
How would they help out my horsepower curve?
Old May 11, 2005 | 09:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
They would help with modification. I would siamese them top and bottom along with port matching. You would need an Edelbrock manifold hogged out or Extrude honed. You would also have to fully port the plenum and probably use a 58MM throttle body.
Old May 11, 2005 | 09:21 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Trying using the search function.
this prevents redundant topics.
"Hi-Flo" or siamesed intake runners have been covered
so many times that I cant count.
you should be able to get all the info you need.
but, ill tell you right now If I had a SB 400 the last thing I would do is put TPI on it.
HSR (Holley Stealth Ram) or Mini-ram would be logical.
do research on those 2 products. If you are stubborn and wanna keep the Tuned Port for looks or whatever reason.. then continue the search for the Intake runners
Im all for TPI .. Hence my name; but a SB 400 has high potential of putting out serious torque and horse with the right combination
there is a time and place for TPI and in my own opinion its not
on a 400 small block.
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
