My spark plug picture?
Old May 12, 2005 | 09:02 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
What does the pictures tell you? lean, rich or what? I took them out and replaced with accel header plugs.
Old May 13, 2005 | 01:32 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Looks fairly normal to me, looks like you might be starting to burn a little oil... is the dark on by the threads oily looking or sooty looking?
Old May 14, 2005 | 05:18 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
looks ok to me also xcept for the black ring might mean something like little unburnt fuel or oil
best way to check for fuel though is to look at the base of the porcelin area but you need some weird **** magnifying lense for that
another thing don't use bosch +4
they are a waste of money.
they aren't designed to give you more power
they don't give the greatest flame travel since the electrodes partially block off how the flame travels
just a normal plug should work a lot better and save you money in the long run
only good thing about the +4 is their design is supposed to last a little longer being there are 4 electrodes but that is it
Old May 15, 2005 | 03:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The base ring is a dark sooty color (slightly rich,) OK for torque, but for max power it should be a light gray. A standard plug would be better, are less expensive, but don't last as long. I know changing them is a PITA, but it's worth the trouble.
Old May 15, 2005 | 05:15 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
isn't thebest place too look for fuel mixture way down inside the plug where the porcilin (sp?) meets the metal?
I've heard both ways but always thought that was the better way to read it
Old May 15, 2005 | 09:26 AM
well if im running a litle rich that should be ok as Im am in the process of hooking up a NX kit so the richness will work with that. true?
Old May 15, 2005 | 02:08 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
yes, but the ring is easier to read.
Old May 16, 2005 | 12:40 AM
Spdfrk1990's Avatar
NGK iridiums best plug
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
