Cam question
Old May 13, 2005 | 06:58 AM
leathalirocz's Avatar
Car: 1988 Irocz
Engine: 355 Stealthram
Transmission: 5speed
Axle/Gears: Stock 10bolt 3.73 posi
Cam question
I am looking to do a cam change on my 88 iroc, it has a 355 roller motor, all forged bottom end done right. But still need to do the top end as money allows, it still has the stock TPI but ported to the max, with 083 cast heads ported to the max as well and running 1.6 roller rockers with 10.63-1 compression. I am leaning towards the ZZ4 cam just to get a bit more power right now and heard it is a desent cam to upgrade too while still being on the mild side. Question is could i run that cam without it causing problems with my stock computer {it does have a ADS chip installed but thats it}. I have a AFPR which is set at 60 psi {seems to run the best there} and with a 150 shot of NOS seems to need it. The specs on the ZZ4 cam are 208/221 Dur @ 50, 474/510 lift with 1.5 rockers and 505/544 lift with 1.6s, 112 LSA. Any help would be great, Chad
Old May 13, 2005 | 10:27 AM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Not a bad cam. I run a zz4 crate and it does not wreak havock on the ecm. IMHO I would go hotcam kit with 1:6 rollers. Want to buy my zz4 cam? got 20,000 on it. I stabbed in a hotcam
Old May 13, 2005 | 11:12 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
ZZ4 is a good cam for a daily driver mostly stock 350. It is pretty weak though. You might try something around a 212/218 cam. I think the LT4 is for a ported/siamesed aftermarket TPI set up really.
Old May 16, 2005 | 06:43 AM
Car: 1988 Irocz
Irocdaddy, how much do you want for the ZZ4 cam? I found a company that does custom chips for 150.00, so i my go a bit larger but just incase. Thanks Guys Chad
Old May 16, 2005 | 09:35 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Sorry for my lateness Chad-
I haven't fired up my car yet after the cam swap. If you go ZZ4; you can have my 20,000. mile cam for 100.00 I have paypal acct. as well.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
