MAF Sensaor swap
Old May 14, 2005 | 12:23 AM
WhoopDang's Avatar
Engine: 350 tbi
MAF Sensaor swap
Will a MAF sensor from a V6 work on my 87 350?
Old May 14, 2005 | 02:41 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: MAF Sensaor swap
if it's an analog type yes, frequency no.
Old May 14, 2005 | 10:25 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Can you elaborate a little on what the difference is or how to tell them apart?
Thanks.
Old May 14, 2005 | 10:43 AM
Vader's Avatar
Externally, there will be no apparent differences, except for the part number. The actual sensor element works the same for both types. The difference is in the output electronics package on the side of the MAF housing. The analog MAF will produce a linear output signal from 0-5VDC that varies with sensed air flow. A digital (frequency moudulation) MAF will produce a square wave output that has a constant p-p voltage of 5VDC, a constant duty cycle of 50%, but varies in output frequency (the number of times the square wave is switched) depending on sensed air flow. Low intake air flow will result in long pulse times (low frequency), and high intake air flow will result in short pulse times (high frequency).
The two types are not directly interchangable. Moreover, the FM MAFs used on different engine types may have a different maximum output frequency. Later FM MAFs used a much higher frequency that earlier FM MAFs.
If you need an analog MAF, try ordering a Wells SU145 through Carquest. According to Wells (as of March of this year) they are still available.
trevor1010
Aug 26, 2015 02:41 PM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
trevor1010
Aug 24, 2015 08:34 PM
Bert87
Aug 23, 2015 03:50 PM
