PROM question
Old May 14, 2005 | 11:00 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
PROM question
Heys guys,
My neighbor just gave me a Prom from a 1986 Vette.
anyway, my car which Had a LB9 5.0L was taken out and fed to the dogs. My new setup .. a MAF L98 backed by a 700r4.
will this 86 MAF vette prom work with a 1989 TPI car?
I was intending to run my 350 with the 5.0 PROM,
instead I could pop the 86 vette prom in that is already dialed in for an L98.
I was told using the 5.0 prom would still run, but who knows how well it would run.
my guess is it would probally be tempermental
-sorry if in wrong forum, but you guys know the most
Old May 15, 2005 | 09:52 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You will have problems. The 1986 Vette did use the same ECM as the 89 F-body but there are differences; specifically the 1989 does not have a Cold Start Injector.
Also, if your new setup is re-using your originial injectors, the 1986 will run overly rich (as the Vette had larger injectors than the 1989).
Get a 1989 eprom setup to work with your configuration. IMO the 1989 programming was one of the better setups for MAF cars.
Old May 15, 2005 | 10:58 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Not sure what year the Vettes started to get aluminum heads, but if they had them in 86, I wouldn't run it. I've looked through some of their spark advance tables, and they go pretty far on timing. Much farther than I would venture to go on an iron headed L98.
I haven't worked too much on MAF proms, but if you take a speed density vette prom (90-91) and run it on a 730, you have to disable code 52. I don't recall what exactly it was right now, but it had something to do with an oil pressure input to the ecm that the F bodies don't have. Its really annoying since it would keep throwing that code on the highway.
Steven 86IROC-Z
May 24, 2026 04:52 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
