Can someone confirm this is normal?
Old May 16, 2005 | 01:22 AM
Cra-Z-Canuck's Avatar
Car: 88 IROC Convertible
Engine: 355 (Finally!)
Transmission: Auto :(
I just put an Autometer machanical oil pressure guage in the car b/c my stock one was reading 0 all the time. New gauge shows about 50psi at startup and then quickly settles to about 20psi.
My question is this: when stopping at stop signs, red lights etc, my pressure drops to almost zero for just a moment - then back to 20. Is this normal?
Old May 16, 2005 | 01:50 AM
Sorry - meant to post this in Tech/General engine. Does someone know if I can move it?
Old May 16, 2005 | 06:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pickup fell off the oil pump.
RBob.
Old May 16, 2005 | 10:29 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I second the pickup also, or low oil level, but since u are worried over the guage I will assume u have checked that? have you?
later
Jeremy
Old May 16, 2005 | 04:14 PM
Simplest solution always wins - it was low oil level. Which is good because bearings not shot, but bad because I just filled it with oil 2 weeks ago - now to find leaks....stay tuned.....
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
89 formula TPI
Sep 7, 2015 11:06 AM
