Start up/Idle problems
Old May 16, 2005 | 03:50 PM
galaxy's Avatar
89, 5.7 IROC. I didn't run the car for a few years, and it shows. Over the winter, I replaced the fuel pump and just finished replacing the fuel injectors. The problem is on starting, I have to keep reving it to eventually keep it started. After that, at idle it fluctuates between 500 and 1500 RPM's. Then it will go between 1200 and 600 and so on until it eventually idles around 750. This takes about 5 minutes. If I shut it down, and start it up again immediately, it idles fine. Once the idle smooths out, the car runs fine. If I wait until the next day, I have to go through the same thing again. We did have a wire come out of the MAF connector, and we may not have fixed it properly. Could this be the problem? Any help may preserve my sanity. Thanks.
Old May 17, 2005 | 09:13 PM
Vader's Avatar
Are you getting a Check Engine light? Error codes? MAF errors are usually latched pretty quickly (within 600mS).
Old May 19, 2005 | 03:14 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Wow you described my problem complety, I am subscribing to this thread so I can follow along in you journy. The things that people told me to do are check for vacuum leaks. That seems to be a major problem with many cars. Just wondering are you getting an intermittant code 34? I am.
Old May 19, 2005 | 03:40 PM
galaxy's Avatar
I haven't been able to run the codes, and I may not be able to work on it for a few days. I still say MAF.
Old May 24, 2005 | 09:36 AM
galaxy's Avatar
No error codes. I'm not sure what to do now. I haven't really driven it yet. I think I'll take it for a long ride and see what happens.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
