hard to start car
Old May 17, 2005 | 03:47 PM
350tpifiero's Avatar
Car: 87 fiero
Engine: 1990 350tpi
Transmission: stock fiero
hard to start car
I have a 1990 TPI 350. Every time I start my car it turns over a dozen times or more before it starts, but most of the time I have to play with the gas pedel to get it going. Once the car gets going, the RPMs are always erratic rising and dropping between 500-1200 RPM. As soon as I take the car out for a drive the car seems to fix itself and the RPMs return to normal.
I don't know where to start, Any Help would be appreiciated, Thanks Bobby.
Old May 21, 2005 | 07:42 AM
Vader's Avatar
Start with the basics. Check base timing. Inspect the plugs. Check fuel pressure. Look for obvious vacuum leaks. Clean the throttles and IAC ports.
Old May 21, 2005 | 08:25 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: hard to start car
THINK IAC motor and TPS settings!
mine used to do that until I replaced the IAC--do search an or may be in the tech articles about how to clean IAC as well as TPS--If I remember right Vader posted an article on the complete procedure.
Old May 23, 2005 | 10:55 PM
formulajokester's Avatar
Car: 91 gta
Engine: 350 tpi
Transmission: auto
tune up is always a good bet also. wires and plugs can help alot
Old May 24, 2005 | 01:11 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my car didnt start up on the first crank until i switched out the old crappy injectors and put new ones in. now it starts perfectly fine
Old May 24, 2005 | 01:23 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had the same symptoms. A few of my injectors were leaky. I also had to play with the gas pedal for it to start quicker.
First thing I would do is check your fuel pressure regulator. Pull the vacum line off it and see if there is gas in it. Then I would get a fuel pressure gage and watch your pressure when the car is turned off. Here is a graph of my fuel pressure after I shut the car off when I had leaky injectors:
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
L98GTA87
Aug 5, 2015 11:02 PM
