Help Oil Leak
Old May 22, 2005 | 05:04 PM
bsw's Avatar
bsw
Car: 87 iroc
Engine: 355 tpi
Transmission: 700 r4
Help Oil Leak
I had my 87 iroc's 350 tpi rebuilt. It started to leak oil in between the oil cooler and the adapter/engine block. A new gasket was installed. It was okey until about 2 weeks later, same thing- it leaked oil again. It does have a high volume oil pump. At idle oil pressure is around 35 lbs in park at 4000 rpm its approx 70 - 80 lbs. Any ideas why this is happening? What can be done? Should RTV/gasket maker be used?
Many thanks
bsw
Old May 23, 2005 | 09:50 PM
bsw's Avatar
bsw
Car: 87 iroc
Engine: 355 tpi
No one?
Nobody has any thoughts?
bsw
Old May 24, 2005 | 01:18 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i wouldnt say the oil pressure has anything to do w/ it. i would say the gasket is just not sealing correctly, so i would replace the gasket again, but use some kind of sealing compound and seal that mother so it doesnt leak again!
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
