fuel filter
Old Jun 2, 2005 | 05:57 PM
DanTheMan_smlk's Avatar
fuel filter
ok, i just bought a 91 TPI 305 but dont have a repair manual. I tried searching for replacement of the fuel filter but got a bunch of results about fuel pumps..so basicaally i need to know where the fuel filter is and anythng i should keep in mind when i change it
how do i remove it....im trying to loosen it with all my might and dont think im doing it right
Old Jun 2, 2005 | 06:24 PM
need help
Old Jun 2, 2005 | 06:35 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
it's under the car sorta but the left passenger seat
off hand forgot the fram part number
any parts store should have it
i think it was a 17mm and 14mm
you will want a flare wrench too
vent the gas tank or pinch off the main fuel line
remove and replace
i also sprayed some wd-40 before
you may need to use vise grips to loosen it
Old Jun 2, 2005 | 07:05 PM
i cant get the damn fittings to budge
Old Jun 2, 2005 | 07:14 PM
Don 79 TA's Avatar
Engine: TPI
10mm to get the canister loose from the bracket
and you will need to use a good pair of vise grips on both ends, line end and filter
or really just on the line end
the filter is 17mm i believe
spray it up first
pinch the line
open the gas cap
i hard to struggle with the one on her car
but it came loose.
keeps some rags around
you will spill fuel
Old Jun 2, 2005 | 08:46 PM
i gave up btw.....im gonna have to get someone stronger to do it
Old Jun 3, 2005 | 04:22 PM
Don 79 TA's Avatar
Engine: TPI
just get under there with some good tools
it should come off
mine needed a lil ole fashion elbow grease so to speak
Old Jun 3, 2005 | 05:28 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i did it with just 2 i think it was 17 mm wrenches?
changed mine last saturday...quite a bit of fuel came out but i was ready and had a co worker hold a cup the whole time while i losened the nuts
oh ya i used some wd-40 to losen them up first...mine where complete rust and i managed to break em wasnt too hard.
oh ya and one more thing make sure u put the new filter in the right direction!
Old Jun 3, 2005 | 08:30 PM
yeah, im too damn weak I even used "liquid wrench" which is meant for tight bolts....i gotta go at it again this weekend
Old Jun 4, 2005 | 03:32 PM
im in trouble, i got the nuts to loosen and changed the filter, but somehow i cross-threaded one of the nuts when i put it back on. Gas sprays everywhere and when the car is off, it wont stop leaking no matter what...anyone know what i can do to make it stop leaking untill it can be towed and fixed propery?
thanks
Old Jun 4, 2005 | 05:14 PM
nvm, i fixed it...it doesnt seem to leak anymore but theres no way to be 100% sure. I put some fuel system cleaner in it afterwards and it seems SLOWER . I dont know if this is because the cleaner stuff or the new filter....what a hassle
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
