Idle problem....how do I do a smoke vac test?
Old Jun 2, 2005 | 11:38 PM
kokamo's Avatar
Car: 73' Nova~~~TPI Powered
Engine: 283 Cubic Inch Rev MUNSTER!!
Transmission: Turbo 350
Axle/Gears: GM10 bolt w/4.56 posi
I am having an idle problem with my TPI.
First off I have a weird combo for you guys.
73' Chevy Nova, 283 motor w/ 10 to 1 compression, decent size cam with very noticeable lope, completely stock TPI maf setup w/ ported plenum. 19* injectors, New maf, new coolant sensor, new O2 sensor, new Tps sensor, new IAC valve, cold start vlv is gone, Egr is blocked off, and prolly more stuff I can't think of now.
It is occilating up and down around 900 to 1200rpms. The chip is set to 900. I have done all the min idle procedures with little change. Fuel pressure is where it is supposed to be. Timing is at 8 BTDC. I don't have access to a scanner so I don't know anything other than there is no codes at all.
I have learned in my past to spray B-12 carb cleaner on the intake where it meets the heads or anywhere else there is negative presure to see where a vacume leak might be. I would love to do this but I don't want to mess up my paint job on the entire thing.
HOW DOES THIS SMOKE TEST WORK???
THANKS!!!
Joe
Old Jun 4, 2005 | 10:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
When the carb cleaner hits a vacuum leak, it's sucked into the engine and raises the idle.
Red iroc-z 305
Sep 30, 2015 05:22 PM
mike_c
Aug 27, 2015 04:32 PM
wayshegoes
Aug 17, 2015 12:00 PM
squiggy2
Aug 9, 2015 09:30 PM
