TPI Tuning for Altitude
Old Jun 7, 2005 | 10:22 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I recently moved from Arizona (1000ft) to Colorado (5000ft). Obviously my TPI doesn't run as strong up here but I was wondering if the are any tuning tricks to make it run a little stronger at the altitude.
I have a '88 with a 350 and MAF TPI.
What can be done to help it out a little? Adjust the TPS a little, adjust base timing? etc?
I am currently running about 5* base timing on my motor. Any help will be greatly appreciated. Thanks
Harley
Old Jun 7, 2005 | 10:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I recall a high altitude chip that GM spec'ed...unsure of what it will get you though. The majority of your butt-dyno loss is due to less air.
Old Jun 8, 2005 | 08:50 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well, u can jack the timing up some, sinc eyoua re at a higher altitude. Not really the right way.
Hit the DIY PRom board and get yourself into some tuning :-)
Will help you out alot and let u eliminate all the annoying things the factory does in our cars...
later
Jeremy
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
