Maf
Old Jun 9, 2005 | 01:18 PM
lesser85's Avatar
Car: 85 Z28
Maf
Is there a difference between '85 and '86 MAFs. I know the '85 MAF operates off of a burn off module and the '86 uses relays. Does this change the sensor design from '85?
Old Jun 9, 2005 | 03:12 PM
LittleNo's Avatar
Car: 91 TPI Caprice
Transmission: TH700R4
i have both, and both don't work
sorry, not a really helpful answer, but i'd be interesting for me if the 86 - 89 MAFs interchange
Old Jun 9, 2005 | 03:18 PM
LittleNo's Avatar
Car: 91 TPI Caprice
i just compared the numbers on the sensors, they are different, but they look like serial numbers; the sensors looks absolut identical
Old Jun 9, 2005 | 10:58 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I believe you can use an 86 t0 89 Maf on an 85 car. But cannot use the 85 Maf on an 86 to 89 car.
Old Jun 12, 2005 | 10:16 AM
Vader's Avatar
The 1985 TPI MAF is a variable frequency output (FM) and the 1986-later TPI MAFs are a variable voltage (analog) output. I have heard of some people using the analog MAF in place of the FM on '85s, but I would strongly suspect the linearity of the input to the ECM as a result of the signal conditioning at the MAF module. It might work, but likely isn't a correct intake air value reported to the ECM.
Old Jun 14, 2005 | 01:13 PM
lesser85's Avatar
Car: 85 Z28
Lets suppose that the MAF on my car was replaced with a newer (86-89) one before I owned it. Could this be the cause on my idle issues?
Old Jul 6, 2005 | 09:00 PM
boneyard buick's Avatar
Car: 1986 buick regal
Engine: 350 tpi
Transmission: th350, b&m shift kit
i got a parts 1988 camaro, and it is the MAF setup. I was wondering if the '88's were controlled by a mass air flow burn off relay? and there is a MAF power relayy as well as a fuel pump relay right? any more relays that should be taken out for a swap?
Old Jul 6, 2005 | 10:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Really need one poster...one topic...
That said...
Wrong/bad MAF could cause idle prolems, but so can 40 other things
An '88 MAF uses a burnoff relay (when car is shut off to self clean the filiment), MAF power relay to supply voltage to the MAF, and all TPI cars, regradless of Year/MAF/SD use a fuel pump relay. (PS I made a reply to your other thread, or one very similar) so try to keep things on topic to the original poster so he gets his/hetr help, and you'll get your help on your thread
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
