Gear Drive & TPI, will it not work?
Old Jun 12, 2005 | 11:50 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I read in Summit that a gear drive isn't supposed to be used with an engine equipped with a knock sensor (like our cars). Has anyone installed one with an engine equipped with a knock sensor?
Old Jun 12, 2005 | 11:52 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i thought a few people did... but i know it has to be the non-noisey type..
then again i could be wrong
Old Jun 13, 2005 | 10:22 AM
Dustin89GTA's Avatar
Car: 1989 GTA
Engine: 355 TPI
Transmission: 700R4 (w/ shift kit)
Axle/Gears: 3.27 (stock)
I had one on my previous motor. It doesn't cause any problems as long as it is a good one(one gear). I'm told the ones with two gears tend to stretch the metal bracing between them.
It will cause any harmonics to be transmitted to the valvetrain. A chain or belt helps eliminate some of the harmonics.
Unless you need precise timing, it's not necessary.
Old Jun 13, 2005 | 11:30 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
i have done several searches on this same topic- both here and other boards- seems it's a toss up some people swear it will be fine- other arque the other way. seems to me it would be fine since it's more of a whine than anything- but what do i know. maybe the people that said the car ran fine- didnt know that it would actually run better if the knock sensor wasn't taking out timing
Old Jun 13, 2005 | 12:16 PM
Guest
Guest
Posts: n/a
I've been waiting for the past 11 years for my knock sensor to go haywire from the gear drive and start pulling timing. I'm still waiting. So are numerous others.
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
squiggy2
Aug 9, 2015 09:30 PM
