sputtering bad vibrations
Old Jun 20, 2005 | 11:19 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
hey i got my car on the road today and the following occurred. i was driving for maybe 20 minutes max. came to a stop and the engine was smoking a little. i opened the hood and the smoke was comming from behind the motor near the firewall.. also, it doesn't sound like its running well. idle is very chopy, and when you go into the power band the power isn't smooth it feels like its sputtering. also my tranny fluid had some bubbles on the dip stick. i really don't know where to start to figure out what the problem is. any sujestions? i bought the car a couple weeks ago and there is no internal engine work that i know of. what could be causeing the sputtering and the smoke?
Old Jun 21, 2005 | 03:24 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
anyone?
Old Jun 21, 2005 | 05:44 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
You should do a full tune-up, it doesn't cost much and it helped my 305 TPI a lot...
Get ACDelco normal spark plugs, ACDelco spark plugs wires, air filter, fuel filter, PCV valve, clean the intake and some stuff with a can of intake cleaner for fuel injected engines... You could also put a bottle of injectors cleaner.
For the rest, I will leave it to someone else since I'm no tech...
Old Jun 21, 2005 | 05:45 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I have a set of Accel 8mm SuperStock spark plugs wires and a NAPA fuel filter laying around. They are brand new in the box never installed. If you wan't them, make me a raisonable offer.
Old Jun 21, 2005 | 05:46 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
thanks for the reply. i'm begining to think it may be the tranny. so i'm gonna drain the fluid and put some new stuff in. then i'm gonna change the oil and get some fuel injector cleaner
.. whats freaky is at WOT the car feels good.
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
