*Need help replacing Cold Start Injector*
Old Jun 21, 2005 | 03:44 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I am going to be replacing my cold start injector soon as that is what I think my problem is. Does any one have any instructions on how to do it? it doesnt look like I have to take off the plenum but the chiltons book says I have to. I dont see how taking off the plenum would help unless I am looking at the wrong part.
Can someone please give me some advice on how to change this part.
Old Jun 23, 2005 | 06:09 AM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
cij is on your drivers side in between the second and third runner from what i can remember disconnect battery first then there should be a torx bolt holding the cold start injector down. pulling off the plenum will make life easier as removal of the threaded feadline on the rear of fuel rail will be necessary so you wont tear the oring that slips on the end of it but if you want to take the chance just remove that torx bolt pull off the old cij and slip on the new one
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
