What Is The Diff. Between 305 And 350 Tpi Injectors?
Old Jun 22, 2005 | 07:18 PM
TOM1960's Avatar
Car: wow thats alot of cars i own , now 1999 silverado
Engine: 4.3 v6,3-350 TPI,71CAMARO SS TPI 350,91 CAMARO RS 350 5 SPEED,86 C-10 350/TH 350C
Transmission: 3-automatics, 1- 5 SPEED
COULD SOMEONE TELL ME EVEN A PIC MIGHT BE NICE TO SEE THE DIFFERENCE BETWEEN 305 AND 350 FUEL INJECTORS? BOOOUGHT SOME STUFF AND TONS OF TPI INJECTORS CAME WITH THE STUFF I BOUGHT !
THANKS TOM
Old Jun 22, 2005 | 07:37 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
the 305's are 19lbs. per hour the stock ones are grey,
350's came with 24lb injectors i dont know the color
Old Jun 22, 2005 | 07:53 PM
TOM1960's Avatar
THANKS MC, BUT IS THERE A PART NO.# ON THEM OR ANY ID MARKS? I HAVE 3 KINDS HERE
TOM
Old Jun 22, 2005 | 08:18 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
are they all the same body color, the stock multec ones should have been color coded
Old Jun 22, 2005 | 09:34 PM
brutalform's Avatar
Yo, Tom your caps are on! And welcome aboard!
Old Jun 22, 2005 | 09:49 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
If they are the early injectors (not the Multecs), this link may be helpful to you.
GM Fuel Injectors for Tuneport Engines 1985-1989.
The table for TPI engines is listed towards the bottom of the page. I can look up the part numbers for the LB9 and L98 Multecs also, if your need to match them to a found part number.
There should be a part number located on the injectors. I almost positive that the Multecs have a part number stamped on the body housing. Others should too.
Mcdamit, actually the stockers are 22# injectors.
Old Jun 22, 2005 | 10:25 PM
TOM1960's Avatar
hey sorry about the caps .thanks for the welcome and jade thanks that is what i wanted those numbers came in handy and worked for me !!!
thanks tom
Old Jun 22, 2005 | 10:36 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
The second generation small block chevy 350 (5.7L LT1)came with the 24 lb injectors.i thought i would a little more info to what was already said.
Old Jun 22, 2005 | 11:08 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
yeah im a screwup sorry, i have too look up the injector info
Old Jun 23, 2005 | 12:29 AM
TOM1960's Avatar
hey thanks everyone ,and mc no one is a screw up in my book u helped alot thanks and *** BLESS everyone to you and yours ! great site , alot of info from everyone !!! thanks again and like i said *** BLESS you all !!!! TOM
Old Jun 23, 2005 | 03:22 AM
billyhoss's Avatar
actually the 93 lt1`s came stock with 22 lb`s, found that out when looking for a set of stock lt1 injectors
Old Jun 23, 2005 | 08:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You are correct. Not many people know that.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
