Code 42 came up?
Car: '88 Red Trans Am w/ T-tops
Code 42 came up?
So code 42 cam up which says bad ignition module. Is there a high performance replacment part? Is this the same thing as the ignition coil?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
did you do anything that might cause this? IE reseting minimum air or anything? If you unplug the electronic timing advance, the brown wire over by the ac, it will cause a code 42 to show up.
Will
Will
no i havent changed anything recently. The code popped up a few weeks ago. I then reset the computer to clear the codes out and it came back up a couple days later. I'll check that brawn wire though thanks. Any other ideas what could have caused it?
i checked for the brown wire but couldn't find it. THe SES light came on again yesterday for 42 and then it went back off again. Any ideas? Where EXACTLY is this brown wire?
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
it has a connector, you need to unplug it to set your timming
I belive it has a white stripe
it could be a bad ignition module, shorting out everyonce in awhile
if you do get a new 1 get Delco, its worth the extra money, I've put cheap parts in cars in the past and had them go after a very short period of time
the module is under the distributer cap, its the thing the wire plug into on the back side of the distributor,
check those wire to make sure they are in properly as well
it has 2 small screws holding it down, if you do replace it make sure you use the grease it comes with the new 1 when you put it in
its not uncommon for them to go
but trust me use DELCO
yeah i found the brown wire, But it was fine. I think I will just put a new ignition module in. Are there any performance differences with ignition modules?
Okay so i got the ignition module tested and it tested good. So i greased it back up and greased any connnections going to it. so we'll see.
