Surging at 30+ MPH
Old Jun 21, 2005 | 10:00 PM
87TAWS6's Avatar
Car: 1979 Firebird Esprit Redbird, 1987 Trans Am WS6
Engine: 301ci, 305ci
Transmission: T/H350, 700R4
Surging at 30+ MPH
Maybe you guys can help me out... Before the 87 was surging and bogging off idle. It seemed to go away after my dad did something a guy at a dealer told him to do(something bout clearing ECU memory). So it was fine today going to class, but then all of a sudden when i got to like 30-35mph it started surging again. When i left class it was ok untill i the car warmed up and started surging again... what is going on with my car?
Also I just bought gas at the mobil a few hours prior to this occuring.
Old Jun 21, 2005 | 10:39 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Could be a tank of really ****ty gas, but doubt it. I would clear your fault codes again, set the minimum air adjustment and check your tps voltage. Those three things should give you a nice steady idle. My car was surging pretty bad last week, came to find out it was a burnt plug wire. But new msd 8.5's and all the 3 things I mentioned before made the car smooth as butter.
Will
Old Jun 22, 2005 | 11:19 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Test your fuel pressure if checking the ignition system doesn't seem to help (make sure you check the cap and rotor too, my 3rd gens seem to love to eat them up in no time!) Also if you haven't ever replaced it check out the fuel filter.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
gt4373
Oct 8, 2015 10:37 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
banksGTA
Sep 13, 2015 11:56 AM
