Another TBI to TPI swap question...
Old Jun 25, 2005 | 10:10 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
Before anyone says anything, I already did a search. But I didnt find an answer to my question. I just picked up a MAF TPI setup for my car. I read the tech article on the swap and it doesnt sound too hard. My question is, will I have a problem getting the car to run right with the stock L03 heads & cam? Within a year or so I am planning on getting a 350 block with vortec heads & a LT4 Hot Cam. (I know I will have to tune then!) Anyway, I also have a pair of non-swirl port heads laying around that I can use. They are from a 70's truck. So they are not the best, but they are probably better than the swirl ports. Should I bolt those on for the meantime or should I stick with the swirl ports.
Thanks in Advance,
Mark B
Old Jun 25, 2005 | 10:16 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
It will run fine just be sure to get 19 pound injectors. You might want to look into getting the injectors rebuilt if they are the original ones though.
Old Jun 25, 2005 | 10:24 PM
cdartz's Avatar
If the truck heads are from a 350 I believe they are going to have a higher chamber cc. That is going to lower your compression ratio and may negate any gains you'd otherwise achieve installing them on your 305. Also your smaller bore may not have enough clearance for the larger valves. I'd change the cam instead, but hey I'm no expert. Better get a few more opinions.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
