Guess my hp gain ?
Old Jun 29, 2005 | 07:58 PM
sam's Avatar
sam
Guess my hp gain ?
Hi,
I was hoping maybe someone has some simillar mods and maybe had their car dynod to know the hp gains
I have the 88 305 TPI AUTO and did the following:
- Edelbrock TES Headers and y pipe
- Hooker 3" cat back (The cat i believe is original)
- Edelbrock High flo TPI intake base plate
- SLP Runners
I didnt change cam though In the future maybe.
Thanks,
Sam
Old Jun 29, 2005 | 08:02 PM
DanTheMan_smlk's Avatar
30 hp?
how much faster does it feel, cause im going to do similar mods...did you do it all at once or one at a time and drive it to see how each thing helped?
Old Jun 29, 2005 | 08:10 PM
brutalform's Avatar
the gains are from the exhaust mods only. Probably around 20 to 30 more ponies.
Old Jun 29, 2005 | 08:13 PM
so SLP siamesed runners are crap?
Old Jun 29, 2005 | 08:19 PM
brutalform's Avatar
I did not say anything about his parts. Any large intake component on a 305 does little to nothing for a power increase. I have been there, and done that many years ago.
If the poster should decide to upgrade to a 350 in the future, he will have a nice induction system to install on it. (SLP runners, and Edelbrock base).
Old Jun 29, 2005 | 08:30 PM
so u dont think they are a worth $250 if they are going on a 305? What would u reccomend doing before that, i have a 305 TPI (small cam, but i want to keep the small cam) with 3 inch flowmaster and SLP cold air intake
Old Jun 29, 2005 | 08:55 PM
brutalform's Avatar
BTW, I saw your red Camaro on another post, Its a nice car.
I would recommend getting all the free stuff you can, then start with inexpensive parts.
You can take your air cleaner baffles out, and stuff like that. Maybe install an AFPR.
Right off the bat, you will benefit from an eprom tune with the cam change. What are your cam specs?
Old Jun 29, 2005 | 09:08 PM
what are the air baffles? im getting the SLP cold air intake...
i have the small cam, 205hp. This will be a moderate daily driver (about 40 miles a week) and i need to keep my gas milage. I will keep that cam forever. Im not trying to build this as a fast gas guzzling car, i just want it to faster than some of the imports out there. What EFPR would you recommend? I am thinking of just doing headers and vortech heads + intake as my primary mods (besides 3 inch flowmaster and SLP CAI). I was also thinking of putting on the Holley super ram way down the road when i can afford it.
Old Jun 29, 2005 | 09:18 PM
brutalform's Avatar
Under your dual filters. There are baffles under them, that allow about 1/2 of the air in. They are mainly used for noise, and keeping water out. I have not heard of any water issues though. My brothers old TPI IROC picked up a tenth and a half by eliminating them.
Sounds like you are on the right track though. My 305 ran consistant low 14s back in the early 90s. With stock, unported heads. Dipped in the 13s once, at a Island Dragway, in N.J.
Fuel pressure is a trail and error deal. No perfect # for everyones car.
BTW, Holley makes the StealthRam, not the SuperRam. Accell makes the S/R.
Old Jun 29, 2005 | 09:19 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
With the peanut cam, I wouldn't be suprised if you hurt the car more than you helped it with the intake mods. Sure, the exhaust is nice, but I'd consider replcing those intake parts, if nothing else, for standard style intake runners at least.
The L98 cam'ed car might have been a different story, but that cam simply doesn't produce over about 4,000 RPM or so.
Old Jun 29, 2005 | 09:24 PM
damnit
Old Jun 29, 2005 | 09:27 PM
brutalform's Avatar
Originally posted by DanTheMan_smlk
damnit
[B]
Dont feel bad, You saved some $$$$ as those pieces are expensive.
Old Jun 29, 2005 | 09:47 PM
should i still put on the vortech heads?
Old Jun 29, 2005 | 09:59 PM
brutalform's Avatar
Keep in mind that the Vortec heads will require a completley different intake as the holes are drilled differently, IIRC.
Old Jun 29, 2005 | 10:05 PM
yes i know
whats iirc mean?
Old Jun 29, 2005 | 10:09 PM
brutalform's Avatar
If I Remember Correctly.
Old Jun 29, 2005 | 11:13 PM
that better?
Old Jun 30, 2005 | 06:39 AM
GOY's Avatar
GOY
Might as well put the edelbrock intake on the "For Sale" section in the classified's, as it Will not work with vortec heads.
Vortec heads will help you, don't get me wrong, but maybe only 15 or 20 HP with that tiny cam. Just do a cam swap and make it easy on yourself. If you got a cam around the 214-216 intake, 218-220 exhaust with .480 lift on both sides, and 112 LSA you would be a much happier man. *Be aware you have a roller cam, before you go out and buy a cam.* I only say that because you didn't match the intake and heads and wouldn't want to see you **** away even more money.
If you *Have* to keep the stock cam, might as well put on the vortec's, sell the edelbrock base, buy the right TPI intake, and hope for the best. I still think ditching the SLP's for standard style, large aftermarket LTR's would be the way to go either way. AS&M seems to be the way to go.
Old Jun 30, 2005 | 12:20 PM
brutalform's Avatar
that better?
DAN, you are "THE MAN" ...thanks again...
Old Jun 30, 2005 | 08:14 PM
sam's Avatar
sam
Well the car does feel better sure does want to rev further.
I decided no more taking apart just adding stuff and by that i mean supercharge is the next step. Besides that would have probably been the cheapest and best power gain from the start.
Old Jun 30, 2005 | 08:37 PM
GOY's Avatar
GOY
EDIT:
Just downlaod the song "Special Ed" - it explains it all.
Old Jun 30, 2005 | 08:50 PM
Originally posted by GOY
What happened to "Im not trying to build this as a fast gas guzzling car?" A blower? LOL.
Best of luck guy.
wait....who exactly are u talking to?
Old Jun 30, 2005 | 08:57 PM
sam's Avatar
sam
I think he got confused hehe
Old Jul 1, 2005 | 09:17 AM
GOY's Avatar
GOY
Yeah, I kinda messed that one up. I thought the guy that wanted to economy was the same one that wanted to slap a blower on their car now.... sorry guys, I'm a little "SPECIAL" sometimes.
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
