Tpi bolt pattern
Old Jul 2, 2005 | 03:45 PM
z28 mike's Avatar
Car: 1991 z28
Tpi bolt pattern
I am thinking of building a motor to replace my 305 but want to stick with my basic tpi setup. I was wondering if I am limited in which heads I can use or is the bolt pattern the same a older SBC intakes.
Old Jul 3, 2005 | 12:48 AM
billyhoss's Avatar
it changed between 86-87 i believe when they came out with the roller blocks , then again for the lt1s but then the vortec tbi`s are different again, heads were the same pattern but the intake pattern was changed from 12 to 8
Old Jul 3, 2005 | 10:39 AM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
if you use an older model sbc... then all you have to do is drill out the center 4 bolt holes so that it makes the same angle as the other bolt holes.. i am in the process of swapping over to TPI on my 79 malibu with a 72 model 350 and that is what i had to do.. just takes a little time and patients....
evilstuie
Jan 9, 2020 08:29 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
