"putting engine back together" headaches
Old Jul 5, 2005 | 10:31 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Where does this go?...its the bracket with the egr and fuel pressure reg vaccum lines on it...
http://memimage.cardomain.net/member...61_98_full.jpg
Old Jul 5, 2005 | 11:06 AM
brutalform's Avatar
The small vacuum line goes to the EGR valve. The long one goes to the port on the bottom of the throttle body ( drivers side). The lines should run nicely under the plenum. A weatherpac male plug plugs into the EGR switch. The bracket itself should bolt to the coil bracket, (small diversed coil). If you are using an aftermarket base manifold, you might have to modify the bracket.
Old Jul 5, 2005 | 12:42 PM
Car: 1991 Z28
Engine: SBC
alright thanks for the help, much appreciated
jhawkeye
May 25, 2022 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
