stupid cold start valve
Old Jul 3, 2005 | 05:17 PM
strider681's Avatar
Car: '87 Pontiac Trans Am GTA
Engine: 350 5.7L TPI (L98)
hey everyone I own an '87 Pontiac Trans Am GTA and am having a hell of a time finding a new cold start valve for it. I tried checker, autozone, napa, the dealer, even Bosch directly who made the original ALL DISCONTINUED. so does anyone know where to find one save the junk yard?? also I am wondering if I can remove all components, block all passages and change some eprom settings to deliver more fuel on cold starts?.. as it is if i let my car sit overnight or for more than 5 hours "cold" then i have to spray carb cleaner in air intake and it starts up right away. like the ecm ins't pulsing injectors on cold start or somethin. spray a little carb cleaner in there boom instant start up. i do hear the fuel pump prime to rule that out.
Old Jul 3, 2005 | 09:20 PM
Vader's Avatar
You should be able to eliminate the cold start and program the ECM with a $6E based binary with extra starting fuel. ARAP is usually a good starting point.
Old Jul 4, 2005 | 01:06 AM
strider681's Avatar
Thanks for the reply Vader! well I did go to electronic school and know some basics about binary and what not but when it comes to programming eproms for an ecm I am a total newb. i was looking at the pocket programmer 2 for around $150 but looking at it i could build that for really cheap. but is there a program that will recognize home made chip burners?..
Old Jul 4, 2005 | 02:27 AM
strider681's Avatar
also is there any other way to help starting cold like maybe setting timing different than factory 6 degrees before TDC ?
Old Jul 4, 2005 | 04:55 AM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
there is a company called standard motor products that produce the valve do a search on the web for there website and then add your car details to find the part
Old Jul 5, 2005 | 12:19 PM
strider681's Avatar
thanks for the info on that standard part but they also discontinued that part.
Old Jul 5, 2005 | 12:37 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
www.moates.net has a USB chip burner for $85. I switched my 86 IROC to the $6E code base and adjusted for the long cranks and no longer need my CSI.
Old Jul 5, 2005 | 05:41 PM
Vader's Avatar
Adjusting the base timing likely won't help. What you're lacking is fuel. You can either replace the CSV with one from whatever source, or reprogram the ECM. I've been running a $6E / ARAP based binary in my '86 TPI with no problems - other than the accelerated wear of the rear tires.
There is a lot of help available on the DIY PROM board on the site, and with Moates' burner and TunerPro software (free) you can be programming PROMs for under $100. You can either modify your stock CALPAK with a socket:
...Or purchase/build an adpater. Again, Moates.net has complete adapters, parts, and just plain instructions to build your own. Mr. Moates has always been a good supporter of tuners and an avid TGO member. It's at least worth a look.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
