Adjustable Fuel Pressure Regulator - Need Info
Old Jul 6, 2005 | 05:48 PM
Black T/A's Avatar
I'm planning on getting an ajustable setup for the fuel pressure. Not sure what brand to buy. I was looking at an Accel #74750. It includes the the diaphram / spring assembly. Other brands are about the same price and afre for the cover only.
Any suggestions
Old Jul 6, 2005 | 10:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Welcome to thirdgen.org!!
I used the Accel, been so long since I put it on, I don't recall any (if at all) problems.
Use the "search" button, and sit back and read the replies to see some pro's/con's of each.
Old Jul 9, 2005 | 09:16 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Accel regulators are nice. Any brand will do well.
Old Jul 10, 2005 | 09:19 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I thought I read some guys were having problems with the BBK afpr screw hitting the bottom of the plenum.
Old Jul 10, 2005 | 03:22 PM
83 Crossfire TA's Avatar
I make my stock one adjustable by tapping out the contour in the end of the housing, cutting down and adding a threaded sleeve (a T-nut) and cutting down the end of a bolt to center a washer to press against the spring assembly:
I did have to recess the bottom of the plenum in that area to get the range that I wanted, but that section is fairly thick. I ended up with an adjustment range of 37-65psi.
When the diaphragm failed and I couldn’t find a replacement one, I got the holley fpr which has a trick machined cap and thumbwheel adjustment plus a specific, shorter spring and diaphragm assembly allowing for a greater range of adjustment and easier adjustment.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
