85 350 tpi prom question
Old Jul 6, 2005 | 08:38 PM
TheKeeling's Avatar
Car: 1985 Z28
Engine: 5.7 TPI Crate Motor with Vette PROM
Axle/Gears: Richmond 3.42
I just changed my 85 TPI from the 305 to a 350 with Ford 24lb SVO injectors. What proms are available for the 85 computer? Right now, it's running waaaay rich, blue flames come out end end of the exhaust manifold when you rev up the motor.
Old Jul 8, 2005 | 08:38 PM
Vader's Avatar
Coool! Flames!
O.K. - Maybe not so cool.
You may have some real difficulty finding off-the-shelf PROMs for your '85, and may find it nearly impossible for a 350 TPI with the 1985 ECM ('870 model). About the only chance would be an '85 Corvette 350 TPI program.
Beyond that, burning your own PROM is the best method, and probably far better than a stock Corvette 350 PROM. You should be able to scale the injector constant to work acceptably with your injectors.
You might also want to peruse this page:
http://www.eecis.udel.edu/~davis/z28/mycar
Old Jul 9, 2005 | 02:05 PM
FLATLINE's Avatar
Car: '85 Corvette, '95 Mustang
www.tunercat.com
My stuff will be here monday. I will let you know how it turns out after the dyno session.....
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
