Different throttle position sensor?
Old Jul 12, 2005 | 08:51 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I remember reading on TGO that someone had found a different tps. I need one that plugs in a different direction that the stock plug in the front. Either on top, back, or side would be the best. Can anyone be of any help?
Old Jul 12, 2005 | 10:43 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Why not just extend your wiring harness a few inches?
Old Jul 12, 2005 | 10:49 AM
SSFiero's Avatar
Car: F350
Engine: Powerstrokin
Go to the junkyard and start walking. Thats what I would do.
I know for certain a V6 fiero TPS will stick out to the side. Some cars stick up, some back. You could also go to the parts store and tell them you need a GM TPS sensor for a custom project. But you want to see them. Any decent store will grab a handful of sensors and let you take a look. The only thing you might have to do is re-pin the sensor.
Edit to add the pic.
This is one that sticks straight up. not sure what it came from.
Old Jul 12, 2005 | 11:14 AM
Extending it won't work, the K&N filter is the large type and won't allow for the TPS to be plugged in.
This is on a friends car, I was just telling him that I saw one that had the same plug was just aimed in a different direction. I've seen pictures of the sensor, but I don't remember which post it was in.
Does anybody know a part number of vehicle that might help me out.
Old Jul 12, 2005 | 12:07 PM
SSFiero's Avatar
Car: F350
here is a pic of the stock v6 fiero TPS. Thats the best I could find in a quick search. It might be a good start.
Old Jul 12, 2005 | 04:56 PM
Interesting, I will have to do some more searching on the Fiero V6 To see if it will work.
Thanks.
Old Jul 16, 2005 | 12:04 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Maybe this is the thread you were thinking of??
https://www.thirdgen.org/techbb2/sho...hlight=lt1+tps
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
