need help
Old Jul 14, 2005 | 07:50 PM
hpbj3's Avatar
need help
I dont know what to do about my car i was driving down the road and it just died. It has no fire and no gas going to the engine and no raido but i have dash, head, tail, and tag lights and the horn still works can anyone help
Old Jul 14, 2005 | 09:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Assuming you're not trolling for fish, you may get more responses with:
Year/Type of F-Body, engine size, TPI/TBI or Carb'ed (or MPFI V6) etc.
Old Jul 15, 2005 | 12:37 PM
hpbj3's Avatar
MPFI V6 2.8L and thats all i know about the car i just got it like a week ago
Old Jul 15, 2005 | 10:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well heck, now we're getting somwhere
Almost seems like you lost a fusable link, I'm not sure where they would be located on your chassis type...maybe someone else will chime in...
You could start by looking at the wires coming off the starter...fusable link looks kinda like a mini blasting cap.
You could try the V6 forum as well, someone with knowledge of your year/engine type may eb able to assist.
I'll look later in my '89 manual to see where the V6 fusable links are located...may or may not be where you need to look, but might be a start.
Old Jul 15, 2005 | 11:23 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
A similar thing happened to one of my friend's 1991 V6 3.1 Camaro. Turns out the wire running from the battery to the starter was shorting against the frame SOMEWHERE near the radiator. I shook the wire while he probed the battery. This demonstrated the dead short between the battery + and -, but after I was finished testing for the wire in question, the car worked so he drove off w/o trying to fix it...go figure...
Old Jul 16, 2005 | 02:07 PM
hpbj3's Avatar
ok now the car will turn over but not start
Old Jul 16, 2005 | 04:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Lets start with a few basics...
It's turning over "normally"? Correct?...not slow and dragging?
Old Jul 17, 2005 | 02:13 PM
hpbj3's Avatar
yeah its turning over normally not slow or anything i checked for spark and its not getting any it gets power to the distributer but no fire
Old Jul 18, 2005 | 05:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Strange thing is it quit completey, now you have power.
How did you check for spark?
Old Jul 19, 2005 | 02:52 PM
hpbj3's Avatar
at first i pulled off the sparkplug wire and put a screw driver in and turned it over and looked for spark. then i checked it with a volt meter
Old Jul 20, 2005 | 07:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You're going to want to pick up a Chiltons manual and start looking for voltage at the coil when the key is on.
Dang, you'd think someone else would jump in here and get ya on the right track, huh? I don't have any V6 experience, so can't say for sure it's like a V8 or not
